Cut/plot not launching...?
Discussion in 'Corel' started by Ken, Oct 21, 2014.
  1. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    Hi Folks.
    Corel GS X5 plus Cutting Master 2 using Graphtec FC 7000.
    When I try to launch the cut/plot that usually opens the Cutting Master screen I get a time out error message.
    I've done a repair install on Draw 5 and have the newest Cutting Master 2 version.
    Any one else have this problem/solution?
    Thanks.
    Ken
  2. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    help...
    Help...
  3. GAC05
    GAC05 Major Contributor
    5,674
    702
    113
    Dec 27, 2005
    Guam USA
    To add onto what Pat said,
    have you tried launching Cutting master directly from the start menu instead of calling it out from within Corel?
    If it opens without the error the cutting master install is good and Corel's VBA launcher might be broke.
    You could look for the file (should be something like "cuttingmaster2.gms") and replace it or reinstall the whole plug-in from the Graphtec site.
    If it won't launch on its own then you'll need to completely uninstall CM and try to reload it.
    wayne k
    guam usa
  4. Jillbeans
    Jillbeans Major Contributor
    14,457
    17
    38
    Dec 24, 2003
    Butler, PA
    Sometimes you just need to restart your PC when this happens. Other times you have to re-install Cutting Master. I save an old version because I dislike the newer one.
    Good luck.
    Love....jill
    PS
    If you do a search, I think I have a few threads on here where this has happened to me.
