I have a graphtec ce5000-60 vinyl cutter and it does a fairly good job with the exception of closing some letters and shapes. I have read a couple posts about getting signgo and using the overcut setting. I currently use Illustrator with the Cutting Master 2 software plugin to cut vinyl. Just wondering if anyone else has had this problem and have found a solution. Oh, also I use a 45 degree blade. Will better software with possibly an overcut function, using a different degree blade, or is there another setting that I'm not aware of. Would appreciate any help.
