Cutter not closing some letters and shapes
jsburk0
I have a graphtec ce5000-60 vinyl cutter and it does a fairly good job with the exception of closing some letters and shapes. I have read a couple posts about getting signgo and using the overcut setting. I currently use Illustrator with the Cutting Master 2 software plugin to cut vinyl. Just wondering if anyone else has had this problem and have found a solution. Oh, also I use a 45 degree blade. Will better software with possibly an overcut function, using a different degree blade, or is there another setting that I'm not aware of. Would appreciate any help.
Jim Doggett
Definitely sounds like the blade offset is too high. Check the default specification, and be sure the enhanced overcut is enabled.
My $0.02,
Jim
jiarby
try oiling the piston..it is probably sticking. The blade is starting to move before it all the way down causing the un-cut spots. The CE THINKS it made the cut, but the blade was stuck.
sinetist
Don't know if this is what's happening to you but when I first got my Graphtec it was doing that on quite a few letter shapes. I discovered that the way it came was set up for pen plotting (the first number on the display was #2). Since I changed that to a #1 (for blade cutting) everything has been fine since.
bob
This most likely is your problem but one, it's not a piston and two, don't oil it. Blow it out with air, oil will just make a nasty sticky mess. If you simply have to lubricate this mechanism just use a little, as in a tiny amount, of graphite. A contaminated tool mechanism. especially the up/down part, is the number one cause of incomplete and otherwise flakey cutting. Just blow it out.
It's not the offset setting unless you've recently changed it for no good reason. If so then it might be, but still, probably not. Offset, once set, doesn't change.
