Cutting Help Needed
Discussion in 'Newbie Forum' started by RaceCutter, Mar 13, 2008.
  1. RaceCutter
    RaceCutter New Member
    17
    When I cut the vinyl out and weed it, there is always one little area thats still conected on each letter .... im guessing this is where it starts/ends .... is there a setting that i can change to make it pass that start/end point to ensure it cuts the letter out fully.
    Thanks, Matt
  2. chopper
    chopper Very Active Member
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    it depends on your equipment, cutter- software,
    what you need to look at is blade offset if you have a manual for you cutter
    it should tell you how to adjust it there, if not look under the hardware section here and see if your cutter is listed and see if there is a thread on your problem, if you cannot find it please list the name of the equipment you are using that will allow you to have greater success in getting an answer //chopper
  3. RaceCutter
    17
    Ok my knife offset was at .15 do i go to .30 or 0 ???
  4. chopper
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    I think mine is at .05 I would try smaller if that wont work try bigger
    you may need to experiment to get it right it will also depend on your blade, let me know if that dose it
    ...//chopper
  5. chopper
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    mine has a an over cut setting also,..you may want to look into that also
    //chopper
  6. RaceCutter
    17
    Alright i'll try that next time ... thanks a bunch for the quick answers
  7. wcso35
    wcso35 Member
    83
    May 24, 2007
    I have my off set at .02
  8. 511graphix
    511graphix Active Member
    550
    Nov 12, 2007
    .011 here
  9. cleancutblade
    cleancutblade Member
    42
    1
    8
    Apr 8, 2005
    Waterloo
    Go alittle bit bigger at a time until the tag goes away. The tags will get bigger as the blade wears.
