Click to Support Signs101 ...
Cutting Master 2 & 3 is working with Illustrator CC 2015 on the Mac platform, but there are issues with the CM installer on Windows. Graphtec is fervently working on a solution, and it should be forthcoming shortly.
Yeah, that is what i'm having to do at the moment. since i'm running windows. It sucked because when installing 2015, it removed my previous versions... so i had to get the direct links and reinstall.
When your installing there is an advanced options button you can click on. Make sure to uncheck remove old versions -- then you keep the older version of software on your computer.
