Cutting Sintra
Discussion in 'Laser Cutters' started by GVP, Dec 10, 2013.
  1. GVP
    GVP Active Member
    829
    19
    18
    Nov 11, 2005
    Swift Current, SK
    Greetings,
    Does anyone have any tips regarding cutting out simple flat panels of 1/8" Sintra?
    I'm finding if I use an up-spiral bit, it lifts the material off the bed in places and can cause the shape to come away, often hitting the bit and ruining it.
    If I use a down-spiral, the kerf fills up with the chips and often re-welds itself back together. Perhaps I need better feeds/speeds? Currently around 16000rpm & 125ipm using a 1/8" bit.
    Any suggestions appreciated - we don't have a vacuum hold-down and clamp everything down.
    Thanks,
    Graham
  2. letterman7
    letterman7 Very Active Member
    1,273
    86
    48
    Nov 10, 2008
    Pennsylvania
    125ipm? You sure about that? Way, way too fast if it is. Back it down to 2, maybe 3 ips depending on your machine. Are you using a climb cut or conventional with the upspiral? Try cutting the opposite way with the upspiral and see if that changes anything.
  3. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    compression bit.
    Up cut on the lower side down cut on the upper side..
  4. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    Just checking my math here, but doesnt 2 IPS = 120 IPM?!?
  5. Z SIGNS
    Z SIGNS Very Active Member
    1,074
    146
    63
    Feb 14, 2009
    Trenton NJ
    Glue it down to a sacrificial sheet of coro and use tabs if need be.
  6. Ditchmiester
    Ditchmiester Active Member
    715
    Mar 24, 2011
    Oswego, IL
    Use a straight O Flute From Onsrud, They cut with no up or down pressure. I cut plastics with them all day long. I love them. I run about 12K RPM and 100IPM.
  7. SebastienL
    SebastienL Active Member
    604
    one pass with the up cut, leave .025" on the bottom(Don't break thru) and .025" on the wall. Finish with the downcut.
    Upcut will evacuate chip better, Downcut will leave a cleaner edge on top.
    If it's very small part.... Transfer tape on the back, Spray "3M Super 77" or equivalent glue on the tape. Just peel off after cutting.
  8. letterman7
    1,273
    86
    48
    Nov 10, 2008
    Pennsylvania
    :Big Laugh yes it does... I read his post as IPS instead of IPM..
  9. synergy_jim
    synergy_jim Very Active Member
    1/8" 2 flute straight - 2 pass - 300 ipm 18000 rpm
    1/4" 2 flute straight - 1 pass - 400 ipm 20000 rpm
    1/4" 2 flute downcut spiral - 400 ipm - 20000 rpm
    The enemy of thin plastic is any upcut bit.
  10. synergy_jim
    also.... the worst thing you can do on a cnc cutting PVC is run to slow. the second worst thing is bad bit selection.
  11. fixtureman
    fixtureman Member
    358
    19
    18
    May 16, 2012
    Medina Ohio
    I use a .125 single flute up spiral bit at 10000 and 4.5 IPS
  12. johnnysigns
    johnnysigns Very Active Member
    1,195
    4
    38
    Nov 3, 2004
    East Coast
  13. fixtureman
    fixtureman Member
    358
    19
    18
    May 16, 2012
    Medina Ohio
    I also use a pressure foot at times to keep it down
