Hi negrozx, sorry for the delay, what I mean with the original point is that point of the axis of the opos sensor, so, it is placed under the cutting head itself. You can try manually to reput it in the original place.
When the opos is pushed inwards, as it is out of place hits the pinchroller when loading media.
It just needs a little pull on the arm. Try to pull manually towards you with the right hand. It is very simple. The problem itself is that the back part of the opos sensor touches the first pinch roller, when solving the problem, you will find that the opos sensor doesnt touch anymore the rollers themselves.
Hola negrozx: se descoloca el opos cuando tienes un enganchón de papel y no pasa de la primera pinza, con la mano derecha trata de colocarlo en su sitio, tira del sensor suavemente hacia ti agarrando el sensor con mucho cuidado con el dedo pulgar y el índice, escucharás un click. Fíjate si por detrás el sensor ya no toca la primera rueda. Es un problema que provoca qe se toque la primera rueda por detrás con el sensor y no pasa de ahí.
