Dead Flexi Help
Discussion in 'Flexi' started by orbitalcustoms, Nov 13, 2008.
  1. orbitalcustoms
    orbitalcustoms New Member
    4
    So our production manager decided to quit today. We have some jobs on the books and cant do anything right now. Anything would greatly help. Here is the error we are getting. Any help would be great.
    Runtime error
    c:\program Files\flexisign-pro 7.5v3\program\app2.exe
    abnormal program termination
  2. P Wagner
    P Wagner Very Active Member
    1,935
    87
    48
    Aug 16, 2006
    San Diego
    With Flexi closed (completely), click Start > Programs > FlexiSIGN-Pro > Clear Preferences. Then confirm.
    You will need to recreate your plotter setups from scratch, but this will solve the problem.
    Bob
  3. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    are they print/cut jobs that are already in the que, and set to register to crop marks on files that are already printed? If so, especially in cases where you might have set repeats in the rip&print interface, you would have the concern of not losing the jobs in the que, because it would be difficult if not impossible to recreate the cut file to finish those prints.
    If there is nothing worth worrying about in the que, then maybe a reinstallation of the program is worth considering. The other downside there would be related to how much customization of your program you might have done. I use mine straight out of the box without customizing toolbars & pallets, so the re-install doesn't hurt me as much... but don't do it on my suggestion unless you understand the consequences, which I don't fully recall myself... things like re-establishing communications with both machines, maybe even re-loading your profiles. I always hate re-installing a program, but you have to consider it as a possible fix for your situation.
  4. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    wow... just read Bob's suggestion.
    Please let us know how that goes. Sounds like a great trick to know.
  5. orbitalcustoms
    4
    That worked perfect Bob thank you thank you
  6. gabagoo
    gabagoo Major Contributor
    5,751
    110
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have not had that problem yet but that is really good to know if and when it happens...thank you
  7. jicamajoe
    jicamajoe New Member
    1
    Clear Preferences works on a mac too
    I had the same problem, saw this thread and tried it on my Mac. (not a fan of mac's anyway but it's a work computer) Obviously there is no start bar so I just made my way to the folder flexisign was in and found the "clear preferences" and click on it. Now it works. Thank you
  8. P Wagner
    1,935
    87
    48
    Aug 16, 2006
    San Diego
    You're welcome - I didn't know that there was a parallel function in the Mac version of Flexi. Thanks for sharing that!
    Bob
  9. Color Dude
    Color Dude Member
    217
    I will say this. 7.5 version is rather buggy. You might want to think about seeing if somebody has a copy of 7.6 you can update to. I have a copy of the 7.7 version that will most likely solve that error.
    Trust me it will come back. If you find that it comes back, let me know and I will send you a copy of the 7.7 disc for you to install. I used that version more than I used my 8.5 and I never had any problems with it.
