binki
Hi all, I have a VersaCamm VS, Eco-Sol Max inks, Orafol calendered printable vinyl. When I print a full bleed the edges curl. I tried a spray laminate ClearJet after cutting and it helped a little. I am guessing I should print, laminate and cut.
My questions are, can I still use the spray laminate or is there something I should use that is better. We don't have the problem with decals that are not full bleed.
