Hands down Jteck has provided the widest color gamut of any ink i've ever seen. The facility in Italy has a gruesome QA department, the ink is waterbased and is a piece of cake to clean up. Every ink they offer has "nanotechnology" which on average saves15 to 30 percent of ink costs compared to most "other" inks. Why do i know this, bc i profile a large amount of different printers from different manufacturers and have found that what they claim is true.
All i know is that OEM inks will save you lot of headaches.
If you are lucky enough to find a third party manufacturer (or even distributor) who actually performs QA testing like the OEMs do, and is willing to back their own product like the OEMs, then you'll do fine.
Then you will pay premium price just like the OEM.
Which would be right around the time this thread was started...... :Big Laugh
Not scared about using 3rd party inks. However, I'll do my homework before jumping on some cheapo ink bandwagon.
Ink has come along way in the last 10 or so years. I find it interesting that many old timers, or people who have grown up in the wide format industry are slow adopters and often shun away new market trends, in favor of "playing it safe".
It helps to know some ground rules when ink shopping... like who actually makes the OEM ink for my printer? Mutoh, Roland, Mimaki don't actually manufacturer ink, but buy bulk ink on contract with an ink formulary company. The ink has to pass high quality standard acording to the printhead manufacturer. In this case, (most cases) it's Epson.
Things to consider is the chemical make-up, particle size, soluable solution etc... with a little bit of homework, and reading MDS Data Sheets it's easy to determine what's going to work and what's not. Getting print samples from the company is a good way to start. Finding others who use the same ink and asking their experiences with it is also wise.
I hear the argument all the time about "Voiding the Warranty" and I don't buy it. That's a fear tactic pushed by OEM's and Tech Support. Leagally, that's not true... we, as consumers are protected by "Magnuson-Moss Act"
They have to prove that any 3rd party product you used/installed was a direct result of it's failure, to void the warranty on that particular part. Not the whole machine. So, if your motherboard goes out, motors or drives fail... they have to prove without a shadow of a doubt that the ink did it. But the reality of the law is that they can't. The only part that's in direct contact with the ink is the print head and hoses/tubes themselves. In other words, they have to have a direct correlation to one another.
Now if you are going to jump into 3rd party inks, use some common sense. Be prepared to buy or have another printhead on standby. Not that you are certainly going to need one... just don't go crying to your printer's tech support when you have clogged nozzles. Also, learn your printer's insides and mechanical workings. You can often trouble shoot your own machine and save time and money. Start by purchasing ink from repituable ink manufacturers. You might end up being suprised to learn that the 3rd party ink that you are getting is the same company that makes the more expansive private label OEM ink! Several of the well established ink manfacturers have relly solid warranties on their ink as well. Meaning, if their product damages your printhead they will repair/replace at their cost!
Again, do some research, and don't let the fuddy-duddy types disuade you from potentially saving your company thousands per year on print costs. In this economy, we all need a competitive edge.
(BTW... I havn't read it just yet, but this months Wide-Format Imaging magazine has an article about 3rd party inks. Betting there will be some links to some of the more repituable ink companies as well.)
Saying an entire brand of aftermarket ink is junk as well as saying all aftermarket ink will cause problems is really not the right way to go about it. Most "quality" aftermarket inks are developed for a specific machine or printhead. For example saying Triangle ink is terrible..... what Triangle ink for what machine and what form (carts, bulk)?
I read all the horror stories too.... yes some people can and will have problems with aftermarket inks. Keep in mind though, people do not generally just post unsolicited positive reviews but they are always very quick to post when they have a problem. There are far far more companies using aftermarket ink than the few you read about screaming that it will wreck your machine like it did theirs.
We have run aftermarket ink almost exclusivley for probably 6 years now. I also had some problems early on with our old JV3. I went with the near cheapest I could get. One form some obscure company no one has ever heard of out of California, that one actually worked great but ordering ink became unreliable. So I gave MegaInk (back when they were their own brand) a try. Disaster. Even with an iOne the colors were wretched and dull. Then gave Image Specialists ink a try. Disaster. Thick gooey and after just a day or so I could actually see the yellow particles coming out of solution and settling in the bottom of the tank. Also started melting things it should not. The stuff was far too strong and just awful.
All this time I know about the bigger slightly more expensive aftermarket brands that everyone has heard of like Bordeaux and Triangle. Well that would be my suggestion.... go with a long time proven brand. I finally switched to Triangle. Yes the color is different, better actually. If you use canned profiles well then you are already used to marginal results whether you know it or not or are willing to admit it. Get the ability to create your own profiles, many aftermarket inks have a wider gamut than OEM. You will expand your ability to hit many colors, reduce ink useage, even if you are using OEM inks. Canned profiles were written for a specific machine (looks just like your but it is NOT your machine), and they were made in a specific enviorment. Things like your shops average temperature, humidity, altitude, and your specific machines quirks ALL affect how the ink goes down and looks.
Many aftermarket inks also have better durability. And many work absolutley just perfectly fine. We have been running Triangle inks for about 4 years now both in our old JV3 which we no longer have and our JV33. Runs great, no premature head failures, no odd color (much better color actually), no clogged lines or anything. We did run the cartrdige version for a while on the JV33 and Triangle did have an issue with the empty flags not popping out on the cartridges. That was highly aggravating but no fault of the ink itself. They have since made changes to correct that as well. Now we use their bulk ink with zero issues.
Even OEM ink can have issues. I remember years ago on our JV3 with OEM ink having all sorts of problems at one point. Finally Mimaki admitted and issue and recalled all of that batch and sent out new ink. It happens, and will happen to any brand including OEM at some point. Stay with OEM though, I encourage it. I like that you spend over double what I do for the same product. Gives me a better competitive edge.
