Letterbox Mike
I'd find a new tech... Cheap banner material will have issues with excessive heat, it'll buckle. That doesn't mean you shouldn't run heat, it means you should experiment with heat settings until you find heat that the media lays flat, if you can't get it to lay flat, find different material.
In order to avoid ink adhesions issues, you need to run all three heaters. Even if you were able to get these printed without the heaters on, the durability of the banners will be horrible because the ink is not bonding to the media properly. Running just the post heater won't really help much. The media has to be hot when the ink hits it, that's the real key. If it's cold it's not soft enough and the pores in the vinyl are closed and the ink will not soak in. Running just the post heater will help it cure a little better or faster, but will not significantly improve the bond to the media.
To give you an idea, on our JV33, we run 13oz Ultraflexx at 42,40,50. We run 18oz Bantex d.s. at 48,45,50. For 13oz supersmooth Bantex (scrimless) we run that at 40,38,50. On all we also run an infrared DigiDry dryer.
