dual monitor
graphix
are they a way to have corel on both monitors (i realize clone will do it) but i wanna zoom in a area on one monitor and make a change while seeing the change on the other monitor....what is a way to do this...? thanks
MikePro
reflect image on both monitors and lower the screen size on your second monitor? it should make the second monitor "zoom'd in". ...i think
worth a shot
Joe Diaz
In the start menu in windows under "Accessories" -> "Ease of Access" is a program called "Magnifier" What you can do is set the magnifier up on one screen and have it magnify your work on the other.
I'm not sure if that is what you are looking for or not.
Rick
Same as in Illustrator.. go to WINDOW.. THEN 'NEW WINDOW'
then move the views where needed and you have a zoomed and an overall view
Joe Diaz
Cool I didn't know you can do that.
The problem is you can't pull that window outside of the Corel program window. At least not in the version I'm using. You would have to make sure the Corel application is stretched onto both monitors. Which can be done.
I have a program called ultramon which is great for multiple monitors. It actually places a few new buttons for multiple monitors in the top corner with the minimize restore and close buttons among other cool options.
