Dye Sub Advancements?
2B
just got back from the ISS show in Ft Worth, and wow what an overload in concepts.
the biggest point that we are looking into are full color garments without using heat transfer materials, which boils down to DTG and Dye-Sub for small runs
Personally the DTG seems to be lacking especially since having to use it everyday and the amount of time that is required for printing onto Dark garments (pre-treatment, laying a white base and then applying the graphics)
Dye-Sub really caught my attention with applying full color graphics to shirts. With no out gassing or pre treatment needed from the printer to the application
Printers seemed to come in 2 categories
1. sheet printers, up to 13 x 19 areas and are small and no rip programs to train on, just design and print. Ricoh seemed to be the leader here
2. roll printers much larger and able to nest the jobs and color the ink usage through the rip. Mutoh and Epson for this class.
What are the pros/cons between the 2 makers
with printers the Espon F6070 seemed to be the newest on the market and offered very detailed printing even without doing the full 8 passes.
However the fact that is is a top load and the material has to go down then back up (making a "U") that seems like it would bend/crease the material and effect the print quality.
with Dye Sub how do you get around the fact that you can not do white onto darker garments?
doing a full color change on the shirt is the first option, are there others? can this be done without having a full size heat press?
what types transfer papers are suggested to have the best image transfer quality?
Can you mix inks? one both there said to mix ink to get the neon colors / more vivid appearance
Which garments are being used? there seemed to be lots of new producers for Poly shirts and the advances with the feels and durability anyone have a chance to test these new shirts?
what are others seeing as far improvements with technologies?
Or does DTG still offer the best options for full color small runs?
WildWestDesigns
On some of the shirts, we would actually embroider white (we use poly thread, not rayon) and then press on top of that. Also gives it an embroidered look as well.
That is one work around that we have used in the past.
Vapor Apparel (to me) seems to still be the best all around, but any 100% will do.
DTG still needs to improve the problem with the titanium oxide in the white inks. Once that is done then it would have the advantage. Otherwise the only advantage that it is is to be able to print on cotton and mix shirts.
Of course, if the "hand" of the print is a major concern (why we don't do other heat transfers with the exception of cut vinyl) then sublimation all the way.
2B
thanks for the input
and yes that is why we are looking at the Dye Sub / DTG as the heat transfer creates a HOT PLASTIC SPOT which NO ONE wants to wear even if it means full color for a short run.
BESTBLANKS
Dye Sub & Other Apparel Decorating Methods
Hello,
Perhaps we can be of some help. We are a premium supplier of Dye Sub printing equipment, supplies (Vapor Apparel, sublimation ink, printers, heat presses, etc) and many other apparel printing technologies. We also offer heat transfer vinyl, DTG inks, digital heat transfer papers, embroidery solutions and many other decorating systems.
Please give us a call 888-431-7385 or visit our site for complete details www.bestblanks.com
