Easy weed white vinyl?
TXGraphix24
651 is really good for the price. I used Avery, only reason why i would recommend it, is because of the blue background which makes it very easy for me, since i cant see as it is.
Doug Pulver
If you are having troubles seeing the cut lines on white vinyl, you can try this. Turn a flashlight on and lay it on the vinyl. As the light shines across the vinyl you will see the cut lines.
