Edge 2 print size
solm96
Can someone tell me why I can only print a max 11.8 inches wide using Omega 5
is this limited by the cutter? It sure looks as though it should be able to do at least 13 inches.
Fred Weiss
It will cut up to 13.2" but will only print up to 11.8" because of the width of the foil, which is only 12" and a small margin is needed. It is, for example, not uncommon to print at or near 11.8" and then contour cut an unprinted white outline around the print.
solm96
Thanks Fred,
If I would have thought a little bit, I guess I could have measured the width of the ribbon.
