I have been in business a few years now and I picked up a used EDGE FX and Envision 375 a few months ago and have been slowly moving away from my original Edge (beige) and HS15. Problem I am having is running an EDGE FX job and plotting on the 375 and getting consistent cuts around the objects from top to bottom. If I run the word CLIFFORD at 1" with an outline at .1 and repeat on the Y 6 times, the bottom of the job's cut is spot on while the top is off as much as .05 to .1. I have calibrated several times, but not sure if it is the EDGE FX or the Envision 375 causing the issue. Does this sound familiar to anyone and or could someone point me in the right direction / forum if this is not the right place. thanks
