I have the same issue with an s80600. Machine is 3 yrs old now, first noticed this happening about a year ago, right before my 2 yr warranty expired. For me I noticed it mostly when printing wraps, and especially if there were large areas of solid colors. Issue wouldn't start at the beginning of a print, would be maybe a few feet into the print and it would start banding. If there were a lot of panels ripped and the printer didn't have a break, the banding would continue. And the banding would get progressively worse the longer you let it keep printing unstopped. If you didn't print back to back, the issue would correct itself and then repeat a few feet into the next print again. To me it seemed like the printer wasn't able to supply enough ink or something.
Had a tech come in and under warranty, they replaced a ton of stuff. Heads, cap top assembly, ducts, etc. Didn't fix the issue, may have improved it a bit, but there was still banding. I kept asking the tech if it could be a pump issue, which he was reluctant about. And honestly can't remember if that was ever replaced, the tech was out here 4 different times over 2 weeks replacing everything. But it just seems like the printer starves for ink if its being asked to deliver the same ink(s) for too long of a period without a break. Because I swear, unless I was imagining it, this printer painted on the solid colors originally, we were blown away compared to our roland it replaced.
So after that we started trying different profiles (we've always used canned profiles) and found a couple that worked a little better. But the best fix we have found is going to 8 pass for anything with solid colors or prone to this issue.
It's interesting that several of us have had this same issue. Hopefully we can get an answer and a solution.
