ERROR 20 , mimaki jv3 16
Discussion in 'Mimaki' started by carloslfigueroa, Jan 7, 2010.
  1. carloslfigueroa
    carloslfigueroa New Member
    2
    Hello to all from Honduras, i have a used mimaki plotter, when i turn "on" the machine, the display show this error:
    ERROR 20
    I/F BOARD 01
    someone knows about it?
    i checked the mimaki manual but dont see a solution for the error. :doh:
    i hope your help, thanks.
    Cfigueroa
  2. astro8
    astro8 Active Member
    790
    18
    18
    May 23, 2009
    Sydney, Australia
    This error means most likely your interface board or main board is fried.
    Time to ring a tech.
  3. carloslfigueroa
    2
    -sigh-
    is possible connections problem on the main board?
    i think wich if main board is fried, i have not other option to buy the main board.
  4. astro8
    790
    18
    18
    May 23, 2009
    Sydney, Australia
    Try all your connections...
    There is a merchant member on here that repairs these boards for a very reasonable price if I remember correctly.
  5. ColesCreations
    ColesCreations Member
    415
    1
    Well...
    If your main board is fried, your heads may be clogged, if they are not flushed. It may be a waste of money to have it fixed, as you are looking at $6-8k to replace the heads, plus the main board. Maybe up to a $10k job...
    You can get a good one for that price, and keep the other one for spares.
    Check before ordering a tech, good luck...
  6. WrapperX
    WrapperX Active Member
    754
    I think he is refering to a PLOTTER not a PRINTER.
