exported image into versaworks
2 see signz
no matter what file or setting i export this picture, it comes up darker in versaworks,
its a photo, imported into x5 , published to pdf, ive tried tiff,eps and jpeg, they all come up the same...darker in versaworks
any ideas...
GVP
Don't know if it's of any help, but I've found you often get a brighter image if you export photo images as RGB rather than CMYK.
2 see signz
yep it comes up darker in VW and prints how it looks on screen in VW aswell...
i tried rgb, same thing, i played with the photo to make it lighter that worked, but it has me confused as to why....
Roto
Your colour management in Corel is not set to the same as VW.
You need to look at colour management in VW & Corel.
See Attached.
Roto
  • Colour management.pdf
Colin
Roto: On that PDF, where does one find that VW "Color Management Properties" screen on the right?
Mike F
Settings > Quality, then at the bottom click "Properties" under Color Management. You can also double click on the Queue A or Queue B folders at the top and that will let you set the defaults for that Queue.
2 see signz
its still doing the same thing even after i changed the profiles...
have i missed something?...
1. open x5
2.new page 300dpi cmyk
3.import jpeg
4.save as eps with cutcontour
vw opens and its darker than in x5
ive tried changing jpeg output to cmyk...no differance
ive tried saving as pdf..comes up file corrupt in vw
Colin
Just a shot in the dark, but have you tried RGB as "Primary Color Mode" instead of CMYK?
scrip
Member
in the publish to PDF
go to the settings
go to the color tab
you will see a button there that you would change to "native" for the color export of your document. This way if your image is in RGB it will stay RGB. if your text is pms it will also export as a pms color.
( then you will save the settings with a name so you will be able to use it again)
2 see signz
go to the settings
go to the color tab
Thank you...
