So my falcon started dropping / not fully printing its magenta cartridge. New 3/4 oem ink, damper is newer also.
Ignore the banding *threw some scrap material in to test print the problem until I figure out what is going on exactly... and any other printing problems other than the magenta issue..
Here is another.
SO, the damper starts full obviously, but then empties? causing the loss of magenta?
I threw a cleaning cartridge, took damper off, and sucked cleaning through... it seemed tougher than it should have, so I believe its probably a clogged line?
I left the solution sit in the line for an hour or so... then drained, then loaded magenta, sucked it all through.
However these are after I ran the cleaning solution through the magenta lines.... I think there is still something in there.
I have never had a problem with the lines before, so do I just change them out completely? I have ordered lines but they will take a few days...
In the mean time is it okay to let cleaning solution sit in the lines over night?
Is it okay to "print" with the cleaning cartridge in (have it marked so it thinks its ink)...
Thanks for any help!
Here is another.
