Click to Support Signs101 ...
Hey guys I am trying to direct print on the magnet material on the fb700 and I keep getting overspray around letters. Does anybody have any suggestions?
Curious. We run a bunch of the same material on our FB700 with the head set to .085" with no problems. Is that the only material you're having issues with?
I thought it was static also but we clean and wipe our material down first before we print onto it. I run it bi directional, I think thats the only way it can print I havent found a uni directional setting.
I would say the head voltage is off, unless it is material specific, then it is static.
Also, FYI, I've had problems with ink adhesion on magnets with UV ink.
Magnum makes a UV Top Coated and it sticks amazing!
What's the relative humidity in your shop? Should be around 50%. In the winter you may be really low without a good humidifier system. A low humidity can cause bad overspray due to static no matter what board prep tpu do.
