autoexebat
yeah it's a blue top , but I set it to CB09U
been full cleaned and used 3 in1 oil
I don't think this is your answer (I'm still going with both blade holders are worn out) but you can also try this. Again I don't think will make much difference but can't hurt to try.
Sometimes Flexi will overwrite your plotter settings. You can turn off the Flexi cutter settings here.
Go to the Cut Plot Screen
Hit the Options Tab
Hit Edit on the right side toward the bottom
Hit the drop down and change to NONE and hit Apply
I don't think Flexi is the issue, but this would be one more piece removed that it may be and it don't hurt anything to make this change.
Again if anything else pops in my head I'll post it![]()
