FC8000 Not Cutting Top Inch - Contour Cutting
RoyalCask
Is there a margin setting or something that restricts cutting within an inch or so of the organ point? If so, can I turn it off?
Thanks all!
WYLDGFI
Maybe your pinch rollers are restricting your width?
1. Scan the media with the pinch rollers WIDER than the media.
2. Open the pinch and bring the pinch rollers in closer or onto the edges of the media.
3. Hit CONTINUE or #4 on your control panel. You now have max width available to cut...but you need to be careful!!
If you're talking about the length...say 1 inch from the lead edge of the media, thats the media eye/ scanner at the front.
