gabagoo
I have a d140 and use a Mimaki printer. One of the most frustrating issues I have had over the years is that the opus reader has trouble detecting the little squares. I have found that certain laminates really need to be worked to get a good read. By worked, I have found that rubbing the squares with your finger for a few seconds seems to smooth out the laminate and reduce the silvering.
I have also found that the cutter seems to have trouble reading the marks on unlaminated vinyl that has been printed on matte material. Now what works even better is if you wet your finger a bit, then rub... it seems to work even faster..I have no idea why, but I will do just about anything to get that machine going so I can get back to other duties.
Again a good rub over the registration marks works wonders.
Those with Mimakis will know that you really never know which marks are going to be used so you still have the waiting game of standing at the cutter and then waiting for the Summa to instruct you to digitize the point.
Now something I learned just yesterday by fluke was that sometimse the cutter head goes into a search mode and this can take minutes before it decides to give up and signal you to digitize the mark. I found that while it is doing this if you twirl the stem that controls the reader up and down, the cutter immediately stops the search and when you put it back down it will resume once more...if you lift it one more time it then signals you to digitize the point. This is a great time saving thing to do. Those that get stuck standing waiting for the cutter to search out the marks will appreciate this...
