first time vinyl wet application problem
Discussion in 'Newbie Forum' started by salvauser, Mar 22, 2007.
Thread Status:
Not open for further replies.
  1. salvauser
    salvauser Member
    40
    I am new to vinyls and signs. I've been following the steps from a vinyl video tutorial I purchased on Ebay. I tried doing a wet application using the home made formula featured here in the signs101 forum. When I tried to remove the application tape off the vinyl, the vinyl would not stick to the surface at all. It almost felt like the entire adhesive washed off. I made sure I squeezed all the liquid from beneath the vinyl and still it would not stick. I even tried blowing it with a hair dryer and only turned the vinyl very soft.
    Can this procedure only be used when doing a vinyl on vinyl application (like shadows or 2 color stickers)?
    The vinyl I purchased does not have any brand on the back of it, but it feels thicker and previous purchases I've made.
    Thanks all for the help. This is a great web site.
  2. Sticker Dude
    Sticker Dude Member
    397
    Mar 26, 2006
    Florida
    you got cheap vinyl off ebay for starters
    but when I do wet apps. I squeegie ALL the fluid out and then Wait 20-30 min for it to dry peel a lil spot to see if it stuck then wet the whole tape to make it soft then you can peel it off
    I always use Rapid Tac its worth it if you use soap and water you might be putting in to much soap
  3. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I didn't know there was any "officially" sanctioned "home made formula" featured here in the signs101 forum.
    sounds like a combination of too much soap in the formula, and/or too much fluid to begin with (regardless of soap content, or ratio) ...and possibly poor quality vinyl, combined with expecting quicker results that can be expected if over-wetting the vinyl.
    solution: use rapid tac & quality vinyl, or use a more carefully mixed homebrew, or spritz it on much more conservatively. After squeegeeing it, carefully see if you are able to remove the application tape yet. If not try again in an hour or two.
    vinyl on vinyl should be fine if the first layer has already been applied. It is not such a good idea if the first layer has not been applied, because if the backing paper gets wet, it could be a problem.
  4. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    No, you should be able to wet-apply to most(smooth, preferably glossy) surfaces.
    Do yourself a favour and get some Rapidtac. The preparation of the surface is paramount. Any oily, dusty surface, silicone ( as in latex paint) will be impossible to apply vinyl to. Room temperature is ideal.
    I was applying some labels(dry) at a local retail shop a while back and couldn't get them to stick on glass jars. Ended up there was a very, very fine layer of drywall dust on the jars that I didn't see. I cleaned with Rapid prep and then had no prob.
    No this is not an advert for Roger. Just my .02
    Cheers...Ken
  5. signage
    signage Major Contributor
    9,487
    71
    48
    Oct 5, 2005
    Penn
    Some vinyls have water based adhesives, and if the vinyl you got has a water based adhesive, it will not work with a wet application.
  6. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    Wow!..I didn't know that...
    Which vinyls are based that way?
    TIA...Ken
  7. PMG
    PMG Very Active Member
    2,453
    after i squeegee the fluid out,I also spray the app tape,this helps lift the tape off the vinyl and substrate!!!!
  8. Roger Bailey
    Roger Bailey Member
    179
    If I may, I will shed some bright light;
    Your application had poor quick bonding because there is nothing in a soap and water solution that stimulates adhesive to bond quick.And yes ad the fact that you may have bought some poor quality film.
    Also, how and what you pre clean substrate with is paramount, you must clean with a product that was designed for vinyl applications, Rapid Tac and TacII were so designed 20 years ago.
    The amount of application fluid used ( speaking Rapid Tac or TacII here ) is only critical in regard to using TOO LITTLE, yes, if the entire adhesive bond area is not wet enough it will trap air in the dry areas resulting in bubbles.
    We don't want you to waste it but, you must get it wet evenly, also the Rapid Tac or TacII stimulate the adhesive to bond faster and stronger, so there can not be TOO MUCH .
    The poor bonding people experience is from using wrong cleaning products and procedures clean only with the Rapid Tac or TacII and a "cheap paper towel" this is critical to a 90 second bond, allowing trans tape removal in 90 seconds !
    And by the way, those films that have "water base adhesive systems" are why we created Rapid TacII !
    Watch my free videos to confirm these facts !
    www.rapidtac.com
    Good luck
    Roger:thumb:
  9. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    And now every one knows why I diss using home brews so much. They do not work.
    Waste of time , waste of good life force.
  10. skyhigh
    skyhigh Major Contributor
    4,866
    10
    38
    Jun 16, 2005
    PA
    "Good Life Force" ?
    Too much Trek there Techman.....lol
  11. Ogriv
    Ogriv Member
    429
    I thought Weasel **** was the best? lol ! Hey I have some Doe urine left over from this years hunting season, mabey I could sell it on Ebay as "Application Fluid". Watch out Rapid Tac, here comes "Doe **** Mist" now available in 1 oz bottles. We don't recommend this product for human consumption.
    Honestly, Don't waste your money trying to re-invent the wheel. Simply use Rapid Tac 1 or 2, apply your graphics, then use the much cheaper water to spray the App Tape. Wait a few minutes and the tape will pull off with no effort.
    Although some people insist on using Rapid prep, I can't say I like it. I have a sample bottle that I tried using on a large glass install, and it appeared to leave a thin residue behind. I'll stick to my denatured alcohol for cleaning my glass to a squeeky clean surface.
  12. imaSIGNr
    imaSIGNr Very Active Member
    2,581
    3
    I usually use Rapid Tac or other similar brands these days, but in the past I have used home brews with good success. I do not recommend them however. But in a pinch if it's absolutely necessary I think they will work.
    You may have gotten too much soap as said here.
    My formula just to compare with what you used is ....1 qt.water: 1 tsp.isopropal alc.: 2 drops of liquid dish soap.
    I don't use this anymore, but didn't have a problem when I did. I was always worried what might happen down the road though......
  13. jbennett
    jbennett Member
    351
    1
    18
    Jun 12, 2003
    Tennessee
    Doe pi$$ takes approximately twice as much active ingredient as does Weasel Pi$$; however, doe pi$$ is more readily available (weasel pi$$ is better). I am hoping that Wal-mMart will come out with an Equate brand of Weasel pi$$ before too long.
    OK, now for some seriousness. I LOVE Rapidtac 1. It works well, smells good too. Roger, When is Rapidtac 2 more suitable than Rapidtac1? It stinks and doesn't work as well for me (probably just because I don't know when it is best to use it). Flooding the tape and re-squeegeeing has worked great for me. I have had better luck with the Transferrite tape releasing easier than anything I have tried. The homemade stuff isn't good for layering at home. It can break down the backing paper and cause it to crumble under the vinyl. Rapidtac is much easier on the backing paper. I lay together two foot tall 4 color race numbers with it all the time. My 2 cents.
    jbennett
  14. dclet
    dclet Active Member
    666
    Dec 23, 2004
    fdsfdf
    1 qt water, 2 drops of IVORY DISH SOAP. and DENATURED Alcohol added to suit conditions.....more in the winter, less in the summer etc etc etc........
    I never had a job comeback because of adhesion problems....
  15. jbennett
    jbennett Member
    351
    1
    18
    Jun 12, 2003
    Tennessee
    Nevermind, Roger, I found your answer in on RapidTac1 vs. 2 in another active thread.
    jbennett
  16. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    Weasel **** recipe for all around vinyl use.
    1-take one spray bottle
    2-fill half way with 91% rubbing alcohol
    3-add 2 drops of Dawn dish soap
    4-top off bottle with tap water
    5-replace trigger head
    6-shake once
    7-Ignore the Weasel ****™ vs. Rapid-Tac™ flame war that erupts bi-weekly on signs101.
  17. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    8-Practice and learn to apply vinyl dry. You can do it!
  18. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,811
    59
    48
    Feb 27, 2007
    World
    Save all the hassles.....Apply it dry, use the center hinge method (Job Done)
    ......NEXT.....
  19. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Go Dry ! ! !
  20. salvauser
    salvauser Member
    40
    Thanks to all. I've never expected this very impressive amount of responses. I'll follow all of your advice.
    Thanks again.
Thread Status:
