Flexi 7.6 unrecoverable error
Discussion in 'Flexi' started by Graphics2u, Mar 23, 2007.
  1. Graphics2u
    Graphics2u Very Active Member
    1,839
    2
    38
    Jan 31, 2007
    Iowa
    Does anyone have a problem with Flexi 7.6 having an unrecoverable error occur when working with Gradients? This happen ALL the time with me! Then it has to shut down and open Flexi again. I never get that error unless I'm working with a gradient color making adjustments to it.
    What's the deal? Any Fixes?
  2. This has always been a problem with Flexi. We use Flexi 8 and we get the same error when speed deleting something like grouped words or small graphics. Flexi claims it's a memory thing.
  3. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    Very annoying. I get the same problem when zooming in very closely on small objects and attempting to edit nodes.
  4. Creative_Lance
    Creative_Lance Very Active Member
    1,123
    Nov 15, 2006
    USA
    I get it when i scroll down on fonts fast.
  5. gvgraphics
    gvgraphics Very Active Member
    2,182
    2
    I was told buy a friend that he increased the virtual memory settings on his PC and that helped with the issue. Might be worth a try.
    Sean
  6. Matthew Scher
    Matthew Scher Member
    109
    2
    18
    Dec 2, 2003
    NJ
    Flexi should never crash, if it does that is a bug (though it may be related to unallocated memory).
    If you have a crash in Flexi 8 that can be duplicated then let me know the steps to get it to crash. If I can crash it here then we will fix it for the next release.
    Just let me know what verison you have and what steps to follow to get it to crash. If it is file specific, or if it happens more with a specific file then send that to me as well.
  7. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    more ram . . . and more allocated virtual memory . . . may help !
  8. BobbyFosson
    BobbyFosson Member
    401
    A bit of hardware information may be helpful as well... Processor, Video Card, Memory, etc...
    You may also try to uncheck the 'Smooth Screen Disply' option in the General tabs within Preferences.
    Correct me if I am wrong Matthew but I have seen a lot of sluggish systems when this option is checked.
  9. Matthew Scher
    109
    2
    18
    Dec 2, 2003
    NJ
    Hi Bobby,
    The smooth screen display works by rendering at 4x the screen DPI, so it can cause a slow down on some systems. We are working to improve that for the next Flexi release.
    By the way, my "favorite" crash in Flexi 7.x is as follows.
    1. select bezier curve tool
    2. click on screen and drag
    3. with mouse button still pressed, press the ESC key.
    Flexi will immediately crash. That is fixed in 8.x.
    Thanks to Cas Technologies for reporting the above issue. It was very hard to narrow down and they managed to find the exact steps required.
