Need Help Flexi P&C 12 - Zoom in and graphics/images turn black
Discussion in 'Flexi' started by BFS, Oct 29, 2020.
  1. BFS
    BFS Member
    35
    4
    8
    Sep 13, 2019
    Oak Creek, WI
    So, I've looked both on here and searched the web for an answer to this and I can't seem to find anyone with a similar issue, nor a solution. It's pretty straightforward, when I zoom in to any sort of logo, text, or other graphic (designed in Flexi P&C, not imported), at some point the image will turn completely black. And the zoom amount to make this happen is not consistent. I'm sure this is an easy fix, but for the life of me, I cannot figure it out.
    Examples:
    https://ibb.co/qmFsrkc
    https://ibb.co/1fQNqkD
  2. balstestrat
    balstestrat Member
    348
    42
    28
    Aug 25, 2020
    Europe
    I would update GPU drivers first.
    But I'm also going to give you the same advice as before, open a case to directly Flexi. They most likely have heard about it or are interested to investigate.
    • Like Like x 2
  3. BFS
    BFS Member
    35
    4
    8
    Sep 13, 2019
    Oak Creek, WI
    I will reach out to them. I just assumed it was an easier fix than an issue that warrants a Flexi call. Thank you.
  4. jimboeejit
    jimboeejit Member
    85
    22
    8
    Apr 30, 2020
    uk
    i would second the graphics drivers....update or check your graphics card...
    i had same problem when card got hot,
    changed to higher spec and issue resolved
  5. Snydo
    Snydo Active Member
    558
    44
    28
    May 1, 2008
    Mid Michigan
    Try hitting F5 to redraw the screen.
