Need Help Flexi P&C 12 - Zoom in and graphics/images turn black
TheBarricade
So, I've looked both on here and searched the web for an answer to this and I can't seem to find anyone with a similar issue, nor a solution. It's pretty straightforward, when I zoom in to any sort of logo, text, or other graphic (designed in Flexi P&C, not imported), at some point the image will turn completely black. And the zoom amount to make this happen is not consistent. I'm sure this is an easy fix, but for the life of me, I cannot figure it out.
Examples:
https://ibb.co/qmFsrkc
https://ibb.co/1fQNqkD
balstestrat
Problem Solver
I would update GPU drivers first.
But I'm also going to give you the same advice as before, open a case to directly Flexi. They most likely have heard about it or are interested to investigate.
jimboeejit
i would second the graphics drivers....update or check your graphics card...
i had same problem when card got hot,
changed to higher spec and issue resolved
