phototec
Having a real bad day, I finally picked a day (Saturday 9-18-10) to install new FlexiSign Pro 8.6 upgrade I purchased in August.
After uninstalling the old 8.1 version, I put the 8.6 DVD in the computer, went thru all the different screens and registering the software on-line, after on-line registration, I was sent an email with a code to reprogram the dongle.
Now when I launch the software, the launch screen comes up, but then when the application starts loading all you can see in the boarder frame (blank in the center, you can see the desktop thru the frame), than in the lower left corner of the frame you can see the loading progress loading fonts, plug-ins, then when it gets to the ADOBE PLUG-IN FOLDER APP.EXE, the application stops loading and freezes, at the top left corner of the empty application frame, it says NOT RESPONDING.
This is really bad, I can't get the NEW FLEXISIGN PRO 8.6 to run, and don't know if I can go back and install the old version 8.1 now that the dongle has be re-coded?.
As part of the loading process, I already registered the FlexiSign Pro 8.6 software on-line, so I'm afraid to un-install and try to install again, don't know what will happen?
I'm really stumped and not very happy with this upgrade purchase at all. It is NOT working, what do I do to fix this and get the application to run?
What should I do at this point?
Thanks for any HELP
Thanks for any HELP
