flexible plastic u-channel
bigben
I'm looking for a supplier, in Canada if possible, to get a flexible U-channel to install on 6mm acrylic edge. I normally use a aluminum version, but I'm sure there is a flexible version also.
Thanks for your help.
Ben
bigben
Thanks both of you for the help. I should had mention this, but I need 10ft and 15ft length. All the distributor you've mentioned only have them in 8ft. I've found some Chinese company that make them in 100ft roll, but I was hopping to find a distributor here first.
bigben
OK, I've found pictures of what I'm looking for. But this manufacturer is located in south africa. I'm sure there is someone that have this in north america.
