flexible plastic u-channel
bigben
Not a newbie
I'm looking for a supplier, in Canada if possible, to get a flexible U-channel to install on 6mm acrylic edge. I normally use a aluminum version, but I'm sure there is a flexible version also.
Thanks for your help.
Ben
bigben
Not a newbie
Thanks both of you for the help. I should had mention this, but I need 10ft and 15ft length. All the distributor you've mentioned only have them in 8ft. I've found some Chinese company that make them in 100ft roll, but I was hopping to find a distributor here first.
bigben
Not a newbie
OK, I've found pictures of what I'm looking for. But this manufacturer is located in south africa. I'm sure there is someone that have this in north america.
