Here is what's happening at this point. 1.) Resolution: the FexiStarter 7.6V2 software defaults to its own resolution even if I change the resolution display for XP. So ulitimately it does not matter if I set a higher resolution the resolution for FexiStarter software won't be effected. 2.) Thus the bottom of the window does not show when I send a project to the cutter/plotter, that is, the preview window that pops up displaying the sign/project that I will send to the project manager. I called support for FlexiStarter they were unaware that the program defaults to its own resolution? So they suggested changing the video card. 3.) After talking with support I now understand there is a send button at the bottom of the window to send the project to the manager I wasn't able to see, gee!
4.) ok here the problem now I can get to the send button, but it does not load the project into the manager? Here is what I am doing - I send the project to the manager, but it does not receive it? So I go to add job in file and the window pops-up and I look through the files but I can't find the project anywhere? I know the cutter/plotter is working because there is a test project when I add it and make active it cuts just find.
