jiarby
Oy! One of the products we make are engraved & sublimated name tags...
A regular customer that we make engraved tags for inquired yesterday about full color tags. After hashing all that out she asks about the turnaround. I always say within 24-48hrs from the time the finished artwork is approved.
She says "great! I will get back to you". This customer is reselling these tags to her customers, she has a business concierge - IT services buisiness and does web sites and print brokering.
A few hours later I get an email...
"we decided to get the full color ones, here is the logo and the list of names... can I pick them up tonight?? Our meeting is in the morning!"
It is 3:10pm. I am already swamped with end of the school year plaque, medals, & trophy jobs with hard deadlines.
I say... "I said 1-2 days from the time the art is approved. You have not provided "ready" art so we have to do a layout then get your approval. I doubt that this will be ready before Saturday. (this was on Wednesday)
No word back.. I go about my business and at about 6:30pm I finish the job I was working on and schlep out the layout and send it to them.
She corrects a name spelling and then says:
Huh? "Deep Blue" and "Deep Brown"?? What does that mean?? I am printing the file THEY sent over (it was a CMYK EPS). It is a "sky blue" with a gradient fade to white. Nothing that you could confuse with "Deep Blue". The "Deep Brown" is CMYK: 32-58-91-18. More of a coffee color with a little too much magenta in my opinion.
Anyway... I couldn't sleep, so I decided to crank those tags out (9 pieces). I set up the master file so that I could do print merge from a CSV and a print imposition layout that ganged them up on a sheet. This way it is easy to make more next time. All I do is point Corel at the CSV and printmerge... double check the centering & width and print.
Then the mfg'ing... fire up the heat press, shear the dynasub to size, tape down the transfer, press the job, peel the transfer, cool, trim the tags,
apply magnet backers, bag & tag, then prep the invoice.
Anyway...
I busted my cajones and got the job done so they could pick them up at dark-thirty in the morning. I left them in a pre-arranges pickup spot outside... kind of a dropbox. I was not there when they got them.
Later this morning I get this email...
I am boiling mad... and shot off a rambling email that said this:
Maybe over the top?? Have not heard back.
BTW... The job is pre-paid. We have cc# onfile and charge each job as we do it for this customer.
"other than that looks good - want to be sure though that the logo coloring matches the coloring of the web color I sent over and not teal and tan - it is a deep blue and deep brown. thanks!"
Anyway...
"Thank you for getting these done so fast. I appreciate it. My concern though is that the colors are blue & brown but the tags are blue & red I'll bring them to the meeting today for review but may need to redo them "
I told you that color profiling is an art…
Color is actually just a perception of how an individual’s brain interprets reflected light that passes through their eyes. Lots of factors affect the light that gets reflected into the rods and cones of your eyes. The type of ambient lighting in the room, the colors of the surrounding environment (walls, carpet… anything really) can affect how a person sees the light that is reflected off a printed surface.
Eyeballs are photon sensitive sensors wired to your brain. They see light and pass that information to your brain where your neurons and synapses compare that information against things it has seen before or against “known” references. That is a great system... as long as everyone has the same sensors and the same reference information in their brain and are viewing it in the same external environment.
Some people also wear corrective lenses over their sensors (LOL! Eyeballs!) to fix some measured malfunction… that is great, but sometimes those lenses alter the light that enters the eyes.. The glasses may be tinted. They may have a photo sensitive coating that darkens them. The lenses may have varying thicknesses, and be made of different materials that filter light in different ways. All those things make a difference in how individuals see color. The fact is that everyone’s eyes are different. Everyone’s environment & ambient lighting is different.
Brown is the phrase you are using to describe what your brain thinks the color is, but it is really an abstract description of a wide range of colors. A thousand different colors could be in the “brown” family, each with a different color value…. Which one do you mean when you say “brown”?
All I can go with is that color in your file is a CMYK value… 32-58-91-18. This means the color is composed of 32% Cyan, 58% Magenta, 91% yellow, and 18% black.
I can print your file again, but will get exactly the same results unless the color in your file is changed. 58% magenta is a fair bit… and it is a major component of this color. Lots of magenta will slide the gamut towards the red side and away from the yellow side.
As a wholesale customer, we print the file you give us. I do not create the file or modify it in any way. If I reprint this file again then I will get exactly the same results. If you want a “browner” brown then the CMYK values for the color will need to be modified.
Ah… but modified to WHAT?? Less Magenta? More Cyan? Is that too much yellow? Maybe more black? Or perhaps some of all those options!? That’s the rub. To do color matching you have to compare a “known” sample of the target color to an array of different blocks of the test color that vary incrementally by only one variable. It is a time consuming tedious process. We print a bunch of swatches, you look at them and if we do that enough you will end up with a color you like. That all takes lots of time and test prints not budgeted into single piece pricing.
Unfortunately, you sent me the order at 3pm and wanted the job done by the next morning. With the end of the school year this week things are quite busy in the engraving and awards business. I do not think you appreciate the effort I expended to complete this job for you. Did you see the time stamp on the email saying it was ready?
Sorry for the rant! How did the meeting go?
