Click to Support Signs101 ...
Mine now does this more and more frequently. I have an LE and I open the lid and gently rotate the printer on its side. There are 3 screws underneath on each side and you open these panels ( more likely the one on the left side) and I ground myself and gently make sure everything is connected properly. It works and the machine is back up and running again. I will warn you that ever since I did it the first time, my shock absorbers have gone dead and I need to use a bungee cord to keep the lid open...so beware that afterwards, do not open the lid and walk away as you could do serious harm to the print head. Good luck
Thank you for your answer Mate! The mine work well, after of open/close the lid many times( 5 o 6), Is possible that any negative (-, earth) connection is not correct .
Thank you again and sorry for my English.
