Need Help Gerber Edge LE Quits Print Halfway and Beeps Like Crazy
Will308decals
Hi everyone,
I am printing on my Gerber Edge LE and the following happens:
I am printing black on top of silver, the silver prints perfectly but when the black is loaded in the printer will go a foot or so and then rapidly beeps at me. I have tried different foils and still have the same issue.
A picture of what is happening is attached. The print will just stop and Edge beep like crazy. I cannot reset or restart the print.
Any input would help!
(Silver now did not print this last run)
Will308decals
Update. Printer wont print anything. It will turn on fine with no noise but as soon as I send a job and click online and get to the actual printing stage, it beeps like crazy. Screen sits on "warming up" while beeping
gabagoo
I know when my starts the beeping, I have to turn off the power, carefully turn it on it's side and then remove the 2 panels to gain access to the computer boards. Usually a loose connector causes the beeping, which one is the question, so I just push them all in and hope I got the right one. Put everything back, turn it on and in most cases the beeping has ceased and I can start printing again.
Will308decals
I have seen your posts in the past. Does yours beep as soon as you turn it on? Or does it beep when you try printing? Also is it a rapid beep that you aren’t able to stop? I cannot reset the printer or anything I have to turn it off for the beeping to quit
the is a document with all the beep coded.
gabagoo
Usually it starts when the printer is turned on, but to tell you the truth I don't really use it much anymore and can't honestly remember....and yes it will continue until you turn it off and try and remedy it.
Will308decals
Hi everyone,
Update for anyone who has this problem in the future: It was an issue with the motherboard. I opened up the printer and it was full of dust so I cleaned it out well and reseated all the connections and it has worked for the last few months with no issues. GMS said new motherboards for Edge 1 and Edge 2 printers are roughly $4,000 and hard to come by so if this issue arises for you, try cleaning and reseating your connections first!
