Ghost Like black on edges
Discussion in 'Digital Printing' started by rgaskins, Jan 6, 2014.
  1. rgaskins
    rgaskins Member
    83
    Nov 9, 2008
    Darlington SC
    Hi all, using a Vp-540 here and I'm getting these marks everywhere in random...If you look at the pic it will be around the edges....Has anyone had this happen before? Changed captops, wipers and do weekly cleanings...Also checked for maybe lint dragging or debris under herds...Thanks for any help....
    https://www.dropbox.com/s/hxgnh42i1z3t1f4/20140106_164250.jpg
  2. rgaskins
    rgaskins Member
    83
    Nov 9, 2008
    Darlington SC
    Your going to shoot me here but I have no idea, it is 68 inside...What are you using to boost the humidity? Thanks so much for the reply!!
    Static is bad here, when laminating all I hear is static popping...
  3. rgaskins
    rgaskins Member
    83
    Nov 9, 2008
    Darlington SC
    Think I have a humidifier at home, pretty good size...Soon as I leave here I'm going to Lowes to get a meter so I will know from now on...I'm thinking you are right on with this because I print wonderful in the summer...Thanks for all the info!
  4. shoresigns
    shoresigns Very Active Member
    1,519
    293
    83
    Nov 1, 2011
    Vancouver, BC
    I had one material several weeks ago that was doing this. I tried all sorts of things to reduce the static, to no avail, when suddenly I realised I had the print head up the whole time. I lowered it and the overspray was gone on the next test print.
  5. stickercuttingcom
    stickercuttingcom Member
    197
    2
    18
    Oct 4, 2005
    a
    Your head could be misfiring and on the way out...this is very typical of heads wearing out, the test print doesn't always have to show a deflected nozzle.
  6. rgaskins
    rgaskins Member
    83
    Nov 9, 2008
    Darlington SC
    Thanks for the replies everyone...I will try to get the humidity up in the am and see what happens...I was using IJ35C...Possible it may be a head going bad...Its been a perfect machine for years, test print looks good but if it is a print head I can't complain...
  7. Saw Trax
    Saw Trax Member
    193
    Jan 2, 2014
    Kennesaw, GA
    If it is a static issue you can also use a mixture of 5% liquid Downy, 5% isopropyl alcohol, and the rest water in a spray bottle. A few sprays around the machine on the carpet ( if you have carpet) can help tremendously.
  8. rgaskins
    rgaskins Member
    83
    Nov 9, 2008
    Darlington SC
    Nice, thanks for the info!!
