Good comparison resource?
Discussion in 'Miscellaneous Printers' started by kazoosigns, Jan 11, 2006.
  1. kazoosigns
    kazoosigns Member
    442
    I've done as much research as I can possibly do by myself in regards to checking out all the wide format printers that are out there. What are some better resources to go to aside from the manufacturer's sites? I'm supposed to make a report at the next management meeting (the week of the 23rd). Any help is appreciated, thanks.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,921
    545
    113
    Sep 11, 2003
    Olympia, WA
    A Google search using keywords Wide Format Printer Reviews returns 47,700,000 pages. I think you'll find more than enough on the first couple of links on the first page.
  3. Jon Aston
    Jon Aston Very Active Member
    1,448
    You might try this...but it is far from "the definitive" resource.
    In my view, printer-to-printer (or spec-to-spec) comparisons are a bit of a red herring. You would be better to evaluate local vendors on the basis of training and support - and let your choice of vendors determine which printer (and RIP software) you buy. And even that is a bit of a red herring...unless you have established a good evaluation process.
    If I was on your company's management team, I would much rather hear that - instead of rushing to provide your recommendation - you would like us to review the evaluation process you have in development...in the hope that we will provide input and/or approve of the process. But (obviously), you know them better than I do.
  4. kazoosigns
    kazoosigns Member
    442
    Thanks for the help. Unfortunately, while typing "wide format printer reviews" is a good start, after a month of sifting through all of it, I thought maybe a couple leads would be more productive at this time.
    I see what you're saying, Jon. My whole point in doing this report is twofold. One, I'm trying to get everyone on board to the idea that creating our banners inhouse instead of subbing them out will benefit us (there's a long torrid story that involves an old Arizona printer there). Two, I'm trying to get past all the manufacturer's mumbo-jumbo and make some recommendations based on first-hand use. Because as they found out previously, had they talked to actual users instead of the manufacturer, they probably would've steered clear of that Arizona. I'm really not in a position to tell them what we should or should not use (even though I'll be the one ultimately using it), I'm just trying to say "Here are the options. These are the pros to Printer ___, and these are the cons to it."
  5. John Miller
    John Miller Member
    145
    83
    28
    Dec 10, 2005
    Branford, Connecticut
    The first thing
    The first thing is to determin what it is that you will be producing. You mention banners. Is that the main thrust of your production? Different printing devices have different strengths.
    http://printingdigital.com
    Is a great resource, post a question like... we intend to produce etc. etc. etc. & our budget is X what printer should we get? I'm pretty sure the folks over there will aim you in the right direction.
