Good fonts with low anchors
Gnomic
Hi
How can i find fonts with a low number of anchor?
Trying to make a collection of fonts, thats best for the plotter, so it doesnt have to to do so much work.
I know the attached image is the worst case and im not looking for decent fonts, but the best there is.
Edit: By Anchor i mean these points thats the cutter has jump between: http://ptgmedia.pearsoncmg.com/images/art_wood6_pentool/elementLinks/wood6_fig02.jpg
Anything helps, thanks :)
Marlene
it shouldn't be that much of an issue for most plotters. what type of fonts are you using that are that messy? are they good fonts or oens found online for free? the free ones tend to be messy. if it really is a problem youcould node edit the copy you send to plot but seems like it would take more time than any extra plotter time. I would suggest using fonts good from a good supplier
James Burke
Fewer anchor points = jagged letters.
The only issue I seem to have with a Gerber GS (no on-board ram) is large curves. There is a slight delay while the data buffers, but it doesn't take all that long. I would rather sacrifice a bit of time for good, smooth lettering.
JB
James Burke
your example is far from worst case as far as number of nodes is concerned
The example shown is surely an easy one. I've found that nodes typically multiply whenever text is imported after it has been converted to curves (outlines).
JB
Techman
Purchase professional quality fonts from a professional quality font maker and there will be a minimum of nodes to worry about. Avoid the free font places and you will be happy.
Font made for the print world (often found on free sites) have thousands of nodes. There was no need to worry about vector machines such as cnc or vinyl cutters..
The Vector Doctor
Chief Bezier Manipulator
JB
Can you explain further?? A good letter O can be done with 8 anchors, 4 for the inside and 4 for the outside circle/oval. I always trace letters and shapes with as few anchors as possible for smooth curves
James Burke
I agree, using curves is best. I use AutoCAD ("start, end, direction arc")to trace and I rely heavily on using curves instead of a multitude of short segments.
The process of reducing nodes, for sake of "fewer nodes" doesn't yield the same effect.
JB
