Gradient banding
Discussion in 'Roland' started by tmac, May 7, 2007.
  1. tmac
    tmac Member
    144
    I Have been trying to print a design that was sent to me as an illustrator 10 file,I am using flexi8 to print on a versacamm and for some reason a small section of the design where there is a gradient is banding when printing.I have adjusted the gradient setting to fine but still banding.Does anyone have any ideas,thanks in advance-Tmac
  2. BobbyFosson
    BobbyFosson Member
    401
    Is this only in a portion of the gradient or all of it?
    Flexi has an option in the RIP/Print for Smooth Gradients... Might try that.
    Also check the EDIT>COLOR SETTINGS... Gradients should be set to Relative Colorimetric
  3. bob
    bob Major Contributor
    5,232
    299
    83
    Nov 4, 2005
    earth
    No. Set the rendering intents to 'Spot Color' for gradients. If you use any other setting you can get some rather creative interpretations of white should your gradient pass through or even close to white.
    Use the Smooth Blends drop down on the printer setup's Color Management tab to select 'Enhanced' or 'Super'. Don't use 'Normal' unless you really don't care what you get for a print.
