Graphic/logo Designer
The Vector Doctor
Chief Bezier Manipulator
Here are some closeup views of that art. I would turn down a job like this. Perhaps someone could illustrate this, but it is not traceable. There is no magic button to make the original suddenly clear to see all details
Billct2
If it were my job to reproduce that "logo" (which looks like it was built using clipart/images) and after I confirmed that the client didn't have anything better (because it was built using low res clipart/images) I would send it to the Vector Doctor and get a price to reproduce it correctly. Then if the customer wanted to pay I would go ahead. And they usually do pay once they realize they have a lousy logo file (because it was built using low res clipart/images).
Welll...since the Doctor has said he would turn this one down, which I completely understand, the other option is to reproduce it from scratch, but I'll bet they wouldn't pay what I wanted.
bob
If you want to enlarge bitmaps without pixelization then you need to get a package that uses a spline fit algorithm. I use PhotoZoom Pro, there are others. Using this sort of package you can enlarge some pretty nasty images. But what you see is sort of what you get. It won't make anything better, just make what you have larger.and may add a bit of pixel bloom, depending.
In general, when you enlarge a bitmap pixels must be added, there's no way around it. How they are added and what colors they should be depend very much on what algorithm you're using. Some are better than others. A whole lot better.
ikarasu
I'm with vector doctor on this. Some of his tats are way, way too pixelated to fix. You'd need someone to re-illustrate them... and it wont be exact, they'll be based on what they "think" it should look like.
who made the file for the customer? see if he can get the original artwork used to make the images... then it might be easier.
