custom sign center
I thought I had my Y position error fixed, after cleaning rails etc. it worked great for a little over a week but long story short I ended up replacing my Y motor.
The Y position error is gone and the plotter initializes normally, senses the media length and width just fine and will do the cut test.
The problem is when I send a file to the plotter it starts to advance the media but won't cut the file.
I performed a factory before I replaced the Y motor hoping that would help and performed a reset when this happened but no change and sure can't figure it out.
I'm hoping it's an obvious setting or something that happened after the reset. I'm going to try uninstalling then re-installing the software but was hoping someone here had some insight that could help me prior to doing that.
I'm running Wasatch Version 7 along with a Mutoh VJ 1204 and Graphtec for my print / cut system.
TIA
TIA
