I cut original airbrush tattoo stencils...normally only one and the change to a different design. I am using Cutting Master 2.
3 issues I am experiencing have not been resolved through the Graphtec dealer nor Graphtec's technical support.
1. When facing the machine from the front, the media moves and cuts the stencil, quite nicely, but it cuts down the length of the media from front to back rather than from right to left eliminating me taking advantage of the 24" media width. How, what, and where to I change defaults for it to go right to left?
2. The second issue is how can I change and manipulate the software or firmware to have the cutter automatically reset itself to the next area on the media that will accept the next tile being printed? Now I must manually move the plotter pen to the next location and reset the origin point each time I start a stencil. (Had a CoPam 2500 and it calculated and did all that automatically)
3. After completing a stencil requiring 2 passes and then loading the next stencil I must go back into the settings of the software and again set it for 2 passes. Shouldn't it stay where I set it initially until I want it to change?
Read the manuals, did trial and error with a pen rather than wasting vinyl and still haven't found an answer. Any help would be appreciated. Thanks.![Thank You :thankyou: :thankyou:](https://signs101.com/images/smilies-orig/standard/thank you.gif)
