Graphtec CE5000-60 Repeat Function
S
Sign-Man Signs
Guest
Lost my manual on our Graphtec CE5000-60. Is there a repeat function? If so, can you share the pad function?
S
Sign-Man Signs
Guest
Huh yea. I mean from the control pad on the unit itself.
thmooch
1. Send the data to be copied to the cutting plotter, and cut or plot data once.
2. Use the (position-arrow) keys to move the pen to the starting position for cutting or plotting.
3. Press the "pause" key to switch to pause mode.
4. Press the "next" or "previous" key until the following menu is displayed. (copy)
5. Press the "enter" key to display the copy-setting menu.
6. Use the up/down arrow key to select the desired number of copies, then press the "next" or "prev." key.
7. The cutting/plotting operation starts for the number of copies selected.
8. To make further copies, replace the medium and repeat steps 2 to 6.
S
Sign-Man Signs
Guest
Thank you. That's it.
