Hi
I have a Graphtec CE6000-120 with a 60degree cleancut blade, with the following issues:
It makes perfect testcuts and if i do a 70cm x 100cm job and starts weeding it, the beginning(or end, not sure which it is) its not problem to weed, but when i get maybe 75% into the weeding, it starts being hard to weed - its not the start/end(hangnails), but more like if its not cutting deep enough(not sure!). If i weed it slow, i can see that the vinyl just dont want to let go. I have to push it down, for it to do the last part of the job. Speed 6, same big lettersize in the whole job.
What might be wrong? Works fine if i do eg. 10cm x 10cm
Weird thing about the testcut:
1. When i go into "cond/test" to make a testcut. It has issues in the left buttom corner = bad testcut.
2. But if i go into "force" and saves it right away(makes no changes!), it moves the head a little and then i make another testcut, then its perfect(every single time). If i then make another testcut, it will do 1. again..
