GX24 Not cutting all the way around.
phuckdrifting
I've searched and I can't seem to find the right answer. I apologize for the noob question but I will try to cover all my settings...
I'm cutting a vinyl on my GX24 and when I weed out they got stuck since it's not cutting all the way around.
I end up having to carefully weed the thing out and it's taking me hours for just 20 pcs...
I'm trying to figure out what the right settings would be that it cuts all the way around.
It's basically the factory default except for the SPEED, which I slowed down maybe because I'm cutting a small sign.
-I have a new 45 degree blade.
-Oracal Vinyl
-13cm/s
-130gf
-0.250mm
But I'm still having an issue weeding and not cutting all the way around my artwork...
I hope this make sense... Here's a photo of my work, are you can see the letters are out of place. :(
Thanks for your time.
-AL
Bogdaniel
add an external contour color white... it should cut the right way and maybe you should increase the knife preassure.
splizaat
That seems like a LOT of pressure. We cut closer to 80g on same vinyl. I'd try another blade -- you may have gotten a bad one. OR if it's a used or old plotter, try replacing the blade holder. The blade holders get bored out over time and the blades tend to wiggle in the holder.
dirtydog50000
How old is your cutting strip. They get digs in them over time and when the blade passes over and over the same spot on the cutting strip there's not enough pressure to cut through. That could b the problem
BobM
Is this a duplicate request on your GX24. Posted a couple of weeks ago "130 gf seems like way to much. I cut Oracal with 80 gf. Start at the beginning. Check the cut strip for ware. Check the blade holder to be sure the blade is turning. Perhaps a tiny drop of oil would help smooth things out. After you are sure everything is working within spec use the test cut feature to tune in the pressure. Good luck."
