Harddrive problems on HP Scitex FB500
netsol
No. If you get the SATA drive with the image. Buy an IDE drive and just image it across. That's what I did in the past. But I no longer have the machine or the image.
youll need a pc with an IDE and SATA port but wont need to change the printer.
there are bit by by bit copying programs that are"partition scheme agnostic" they can copy anything
i have a machine from csc in california (he invented the modern ide partitioning scheme, and was the sole seagate servicer of hard drives for almost 20 years)
it can copy any proprietary partitioning scheme
for SATA & SAS you need to use a software solution.
i have been told those weird little cloning devices running linux on a chip can sometimes work wonders, but i am not sure, you would have to try it
sbergman
We owned an FB550 for 3 years. At some point HP warranty accidentally sent us a HDD - part "L1Q41-67086". We have since sold the machine, but I still have the HDD. It is in the wrapper and never used. If you PM me I am sure we can work something out and I can Fed Ex out today.
Maandeev
Hello Everyone
I am going through the HDD problem on hp scitex fb 550. does anyone has an ISO for the firmware or the software that I can load on my HDD and get my machine up. I have fb 550 stuck at HP logo during boot up. I am pretty sure that it is due to the corrupt software. Please give a link from where I can get the software. Thanks.
sonnyphoto
Hello Everyone
Does the 550 use the same hard drive as the 500?
Maandeev
That sounds good. I installed a new board. can I get the image?
It is not possible to make an image of the HDD. it is better you get a new one. I got a new hard drive and cloned it using third party cloning software. my machine is running on a cloned HDD now.
Mogtr
My FB500 had a sata HDD, which I believe failed.
I purchased a working IDE hard drive out of a used machine.
I took an image off this IDE HDD using free online software. I purchased a cheap SSD 256GB of Amazon and put this image onto it.
It works really nicely in my machine and boots quicker than before.
I have the image file it’s 130GB however, for anyone that’s stuck.
Rho205user
Can a hard drive for the FB500 also boot an FB700? I made a mistake updating the firmware; I installed firmware version 12 on a machine with an Intel motherboard, and now it no longer recognizes the partition 2.
Could I receive the disk image? Thank you very much.
Rho205user
After many hours of intense work, using a Linux PC, I accessed the shell directly as a super user. I cloned the disk with the wrong firmware, so I could work on a clone without further risks. I restored all the files to the previous version.
