heat transfer problem help!
Discussion in 'Printwear' started by chopper, Jun 3, 2007.
  1. chopper
    chopper Very Active Member
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    Hey guys & gals I tried the siser color print material the other day and had a problem. when I went to remove the backing paper it tore and after it ripped I couldnt get it off the back of the material I ended up throwing them away
    I thought I was cutting to deep so I went back and checked the cutter and did some test cuts to make sure it was correct, reprinted the graphics and the same thing happened, I talked to the siser rep and he said that it was the mask I was using..I am using transfer rite low tack he said I need to use their mask, what mask do you use, and has anyone had this same problem? Thanks//chopper
  2. TrustedImages
    TrustedImages Member
    182
    Is that a paper mask or a clear mask? I'm not that familiar with transfer rite. Also it might be better to use a teflon sheet instead of masking tape.
  3. mystysue
    mystysue Active Member
    999
    5
    38
    Mar 14, 2006
    IM not sure what transfer tape to use.. but to answer Trusted Images question.. Its a papermask..
    and teflon sheet will not work for this application it has to be a transfer tape of some sort..
    Chopper..
    I think i read on here somewhere what others use..
    so mabe a search for color print would help..
  4. TrustedImages
    182
    Why can't you use the teflon sheet with the color print? I'm not that familiar with the heat press materials. Well I am just not the ones you print on then apply. I know that if you use tape you have to use some sort of paper tape. The clear stuff will melt.
  5. mystysue
    999
    5
    38
    Mar 14, 2006
    Trusted.. its not like the other heat applied vinyl where you cut in reverse and use the backing on top.. You need a way to transfer the printed vinyl to the shirt..
  6. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    I use the cleat AT60. Works fine for me.
    I use Colorpint all the time, never had a proble quite like that....?
  7. PMG
    PMG Very Active Member
    2,453
    I use R tape.
  8. MobileImpact
    MobileImpact Active Member
    759
    Standard tack r-tape. Works perfect 99% of the time.
    Kevin
  9. high impact
    high impact Very Active Member
    We use color print from Siser all the time and it works great! We use the mask that comes from Siser called "uni-mask clear" - I just looked and it is on an avery roll and has a yellow backing.
  10. Jackpine
    Jackpine Major Contributor
    Sign Warehouse calls Siser color print , "new colorprint". I just used some last week I bought from them with no problems. I used transfe rite paper tape and it is the 475 high tack but that does not matter low tack should be ok. I peel when the print is just a little warm, than repress with a silicon sheet. The reason I use the transfer tape is to get the print on the garment. I have had problems getting the print off the backing when I used Roland HTM, but not with Speciality Material's colorprint or Siser or Solution's from Imprintable Warehouse.( Josh Ellsworth 800 347-0068)
  11. Josh Ellsworth
    Josh Ellsworth New Member
    16
    Our Colorprint II material is actually the "new colorprint" as well. We have a new mask called TTD Mask that I tested with the material this morning. It works way better than the other mask that I was using. Has a lot more rigidity, is a hot peel after application and can be reused (I reused it 3 times).
  12. chopper
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    I dont think you are under standing my question but I will try again,
    I am printing on siser new color print material with my versacamm it prints fine, I let itsit for ink to cure, weed material that is unwanted,
    which works fine, then I apply the mask, but when I remove the graphic from the backing paper to apply it to the shirt I cannot get the backing paper off the back of the graphic with out tearing the backing paper, so I end up with backing paper stuck to the back of the graphic and I can not get it off ,
    I was told that it was a problem with the mask I was using but I dont really think that is the problem need help!!!//chopper
  13. Josh Ellsworth
    16
    Whenever I have encountered this its been because I have cut too deep. Another instance where this has occurred has been when I was weeding and accidentally pulled up a bit of the backing paper, then upon masking the paper pulled up.
    And it still could be due to the mask you are using if the cutting force thing doesn't work.
  14. high impact
    90% of the time it's too much cutting force.
  15. chopper
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    thanks everyone for the input I will try the siser mask and see if that makes a difference //chopper
  16. Charlie J
    Charlie J Very Active Member
    1,876
    7
    38
    Oct 1, 2006
    Midwest
    Are you letting the graphic cool after you press it? I have had luck in waiting about 5 minutes before removing the transfer. I'm using roland HTM and tranferrite low tack
    This link may help.
    http://www.wensco.com/transfer.wmv
  17. chopper
    1,197
    4
    38
    Mar 18, 2006
    Big Lake MN
    hey Charlie,
    that my name too,
    anyway I am not getting to the part of applying the graphic, this is all happening before application to the shirt, I cannot get the material to release from the liner, to apply it to the shirt//chopper
  18. PMG
    2,453
    Sounds like either its a bad roll or your cutting to deep,i get this some time when i cut the metalized films as well as the color print to deep!!! The deeper you cut the harder it will be to get off the backing. JM2cents:thumb:
  19. Jackpine
    I do a test cut on the material (a triangle in a square) to test the cutters setting for the material. I cut when I can weed easy and there is very little or no indent visible on the carrier sheet after I do the test cut. Saves a lot of problems from material to different material. I use a 45 degree blade. I peel the transfer paper off warm with the Siser material.
  20. D & R
    D & R Member
    33
    Just a though do you have the heat turn off on the drier. it it might start the heat transfer proses.
    good luck Dave
