Hello to all and I have a LINX 60 problem!
Discussion in 'Miscellaneous Plotters' started by etcetera, Apr 6, 2010.
  1. etcetera
    etcetera New Member
    3
    Hello every one I just signed in and was wondering if some one can help me with a problem that I have with my linx 60 from GCC.
    I havd this plotter for about 8 years now and been haveing trouble with it
    it just wont cut,
    I have been working wit corel draw 12 and cutting from it and WinXP sp3 since I started, with my PC (No.1) and now just displays an error when I try to cut.
    the data clear goes on and error light blinks and wont cut.
    I used the serial cable connection (com1) always and when this started tried the same with a second PC and it was the same thing.
    then I changed the serial to a usb to 232 cable and worked ok for 2 days
    but now it just wont work with my PC no.1 and Pc No.2 .
    I was wondering if anyone in the forum have some experience with this kind of problems.
    I was thinking that is some kind of virus or something becouse I sarted transfering files to cut from PC No.1 to PC No.2 and after 2 days it just stoped working .
    or could be something wrong with the mainboard of the linx 60 plotter
    i was thinkin of backing up mu data in PC1 to reformat and reinstall Windows XP .
    thank you for any advise in advance.
  2. Finishline Signs
    Finishline Signs Active Member
    948
    Jul 3, 2008
    Crestview, FL
    I worked on one that had the same problem. We finally determined that it was the main board that was bad. Signwarehouse give us a price of $600 for the board. We trashed the cutter and got another one.
    You might want to introduce yourself on the forum. You will get more help if you do.
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    welcome from cali :thumb:
  4. TheSellOut
    TheSellOut Very Active Member
    1,355
    Welcome from PANY
  5. Gino
    Gino Premium Subscriber
    33,365
    2,344
    113
    Jun 7, 2006
    PA
    Welcome from Pennsylvania......................................................
  6. etcetera
    etcetera New Member
    3
    thank you and you are right, sorry.
    My name is Daniel Vega From Matamoros Tamaulipas Mexico i have been in the sign bussines since 2002.
    I have been doing signs from hand painting to neon, lighted signs and channel letters
    I own a little sign shop and want to keep doing what I love doing most.
    and yes sign warehouse have been helping with this I just didnt ask for a cuote on a mainboard I guess I was thinking of fixing it somehow but now its time to move forward and see some other options or not too expensive ones at this time!
    Ill ask SW the current price for that mainboard and see how it goes.
    thank you!
  7. The Big Squeegee
    The Big Squeegee Major Contributor
    4,960
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Welcome from OK USA
  8. round man
    round man Active Member
    637
    1
    you might want to check and be sure windows hasn't reassigned another port to the usb adapter,.,go to control panel then device manager then to ports and see which port is assigned to the adapter,.,.sometimes windows decides to change the port for the adapter all by its lonesome,....hope this helps ya,.
  9. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    do the self test on the cutter itself. If it will not self test,, its dead.
  10. etcetera
    etcetera New Member
    3
    thank you for all the comments!
    Well I dont know how can I do a self test on the linx 60 maybe theres a demo cut test or something but I far as I know havent read it or find it anywhere in the manuals and stuff.
    Al it can do is move manually left to right, back to front and viceversa and the cut test, and the cut origin.
    If someone knows how to do this I ll thank you!
  11. Newbie_on
    Newbie_on Member
    101
    Time to move on and get you a new cutter with new warranty, your cutter model it is obsolete!
    Good Luck!:Welcome:
  12. Compilla
    Compilla Active Member
    733
    Ditto
  13. jscarl
    jscarl Very Active Member
    1,987
    Welcome.
  14. cfbeagle
    cfbeagle Member
    148
    Can't answer your question but...
    Welcome to :signs101:
