149motorsports
User # should be on the key as well. 6 digits I believe. Is it a usb key? If so does windows recognize it when you unplug it and plug it back in? If not it may just be a key driver problem.
You should lose files by reinstalling, especially if they in My Documents. You may lose Profiles for your setups in Production manager, and any color tables you've created. What you can do is Rename the Flexi Folder in Program files, by just adding a 1 or 2 or something to the end of the folder name. then reinstall. That way you will have all the files saved if you need them later.
yes, i plugged it in and nothing was ever recognized. no it is not a usb key
