I have a Rolland VersaCam SP 300 and did not use it for about 8 months.Because I intend to seal the printer,I did a test print but nothing come up.I also tried a couple of medium head cleanings with the same result.I called the technicians who serviced my printer for the last 4 years and have been told that most likely the printing heads dry up,and should be changed.They are asking $2000.
Anyone out there encounter the same problem?Do you think that the print heads are the problem?Is there anything else I should do to fix it instead of spending two grand? If not ,should I change the heads or try to sell it the way it is.
Thank you all.
Thank you all.
